FreeRanger's avatar
FreeRanger
Awning switch wiring - Weather Pro
I have a A&E Weather pro on a 2005 Southwind. I removed the controller box because it was cr-- . Now I have no power to the main roller switch. There were three wires going from the box to the roller switch. My question is can I somehow rig jumpers from the pigtail that fed the controller to power the switch or do I have to rewire? Wiring diagram would be helpful if any electrical gurus can help.
  • nbounder wrote:
    Chris - it seems obvious to me that you and Doug are beating your head (s) against a wall here. Perhaps you folks have better things to do than argue...probably.
    Who is arguing????????? Doug
  • dougrainer wrote:
    SCVJeff wrote:
    That also defeats all the fail-safe devices, and that becomes a liability for a shop to work on it, bla-bla..
    You could probably make it work with a DPDT ON (mom)-OFF-ON (mom) rocker if that's a quest.
    What Fail safe devices?????
    The roof/arm wind sensor is an option and the Ignition interlock is an option. Doug
    Those are the ones, and I've had trouble with both.
    That comment relates to a warranty fix on the ignition interlock. They had problems chasing it down, I said 'pull it', they said 'can't'.
    You are correct. IF under warranty, then do NOT modify any device on the RV, unless the OEM says to do it. Doug
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
