fcooper
Jun 22, 2013Explorer II
BFL13 wrote:
Sounds like a neat DIY cure. I have an issue that it rolls up, ok but kind of off to one side so the two support legs don't overlap right. I read that the cure for that is to loosen the upper end and shift it over and re-tighten the upper end. Not done that.
Is there a similar easy cure for what I have to what the OP has?
Thanks
I have the same problem, and I think it is wear on the arms that let the awning move left and right. Having the pull strap exactly in the center, watching how it rolls, and pulling to the side to offset the wrong overlap often works for me. Sometimes, I have to make two or three tries before it rewinds evenly.
Fred
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
