DrewE
Mar 18, 2016Explorer III
For protection against abrading, you can put it in corrugated nylon/plastic split sleeving or similar protective tubing. If it's secured reasonably well against movement there will be little abrasion (with our without additional protection). If you can zip tie it to the structure or attach it some other way that would be good.
How are the tail light wires routed in your trailer? Can you follow the same routing?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
