HiTech's avatar
HiTech
Backyard boondocking - 600w load test
It was surprisingly hard to find 500+watts of steady load around the house that still fit within the limits of my inverter (10ish year old Vector 700/1400 watt unit). Everything was either too big (e.g. heaters) or not constant duty cycle for a few hours.
I finally ended up with a 250w heat lamp, 100w lamp, fan and stereo. So I have my fully powered campsite in the backyard, off the grid.
The kill-a-watt started off at 501w of load but reads 493w as the voltage drifts down. The Turnigy is currently reading 53 amp draw and 599w at 11.26 off my second favorite 12v supply, a 2 year old Duralast 115Ah marine battery. Voltage drop from the battery to the inverter is .09v (I was worried about the small gauge wire on the turnigy but it is very short, then a little run of 4 gauge on one lead). Ring terminals on all connections.
Not really worried about the exact timing or load profile on this battery as it discharges, though it is interesting to see how well it is keeping voltage up under a sustained load. This is a dry run for the same test on the AGMs.
Waiting a little longer, 10.87v and 65.5 amp hours tripped the alarm at a bit over a 54 amp load. Time for a recharge.
Jim
  • 500 watt quartz construction lamp works great for load testing generators and the like. $10 at HD/Lowes/WW
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
