Cstoliker's avatar
Cstoliker
Bad Caliper or something elce?
Been having some trouble with a break sticking when hot. Seams to be the left rear. I've replaced the pads, brake hose (on that wheel), greased guide pins and of course, bleed the system.
After the rig has sat for a while the brakes with work well but after getting hot it some times sticks. I've driven recently an 80 mile trip (mostly highway) and had no problem. But then a quick 5 mile trek to get a safety inspection it started sticking on the ride home.
Normally when the sticking occurs I'll noting a pulsing when breaking that's not normally there and at low speeds squeaking.
Before a replace the caliper, is there anything else that could be the cause? Both roters routinely get to 450 degrease after driving so its possible both are sticking to some extent but the left you can smell burnt brakes when it happens.
Is this typically of a bad caliper? Failing only when hot and sometimes working normally?
I guess the best diagnostic procedure would be to drive it it happens then crack one of the bleeders open and see if the system is under under pressure.
The first time it happened was on a trip home from camp. It got so bad I pulled over and dumped bottled. Water on both rear calipers (I know not a great idea) but after doing that they seamed to work fine the rest of the trip home.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
