joebedford
Aug 05, 2019Nomad III
ItsyRV wrote:Good point - that happened to mine. The city water inlet is the second from bottom white hose on the right in the photo I posted above. A short length of pex then flexible hose. I had to loosen the connections and twist the hose to get the kink out. You can see that it's still a bit restricted but not bad enough to worry about.
If the city water inlet is connected to a flexible hose/tube inside, it's a remote possibility the hose/tube somehow got kinked and is restricting flow.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
