Smitty77
Mar 26, 2018Explorer
Point taken that I should have included the link that referred to balance charging.
https://www.iotaengineering.com/pplib/balancedcharging.pdf
And even though I've had a few RV'er's tease me because I do a yearly cleaning of the AGM bolts and interconnects, I did so proudly. Always feel it is good to poke around doing routine maintenance, as it give you chance to spot small problems and resolve them before they become larger ones.
9" and 14" interconnect cables, so the same lengths for their duty. I did not make these cables, and with heat shrink on the connection points, not sure if they're soldered or not.
It was the best practice for charge attach points for a 4 battery setup that got my interest, as mine were not set up this way.
Best to all,
Smitty
Note: Hope to pick up the new Lifeline L16's either later today, or Tuesday. And then will do some measuring on any new cables I might need to attached in a balanced method.
Best to all,
Smitty
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
