DrewE
Jul 05, 2018Explorer III
westend wrote:
Balancing between the two legs is the way to go. 17A on one and 14A on the other is fairly good. Your water pump or a circulating fan would use about 3A.
The water pump is a 12V load, so would be accommodated in the converter or inverter-charger load. I doubt it would amount to 350 VA. It might use 3A at 12V, or somewhat more, when running.
An absorption fridge on AC power uses about 3A or so.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
