HTElectrical
Jan 24, 2021Explorer
You could also eliminate the transfer switch by connecting power directly to your electrical panel and see if the issue is still there. Check to make sure your Neutral connection is tight, breaker is not shorting out where it snaps onto bus bar, and also lug where your 120v line connects at bus bar is tight.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
