dougrainer
Jan 24, 2021Nomad
1. I would REPLACE the ATS. Why? Because you state it has worked for years. ATS boxes have Points and those points get pitted over the years and will not securely lock in place when the relay's transfer. You could attempt to file the pitted contacs but it is better to replace the complete ATS.
2. Now, you COULD open the ATS and find the GEN INPUT and the OUTPUT to the RV Main breaker box. Disconnect those 2. Using heavy duty Wire nuts, connect the Black to Black and White to White and Ground to ground and then run the system. IF you have no problems, then the ATS is the problem. Doug
PS. the actual Amps of a RV AC unit is 11.5 to 14.2 at ambient temps below 95 degrees, depending on the BTU size of the AC. Lower than 95 degrees the amps drop.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
