wa8yxm
Jan 24, 2021Explorer III
wa8yxm wrote:HadEnough wrote:
How would that be possible when the behavior happens with the air conditioner OFF???
AGAIN, IT’S AN ELECTRICAL PROBLEM
My Mistake, Thought he said it happend with Air Conditinoer on.
Ok true story time
Now in my case it was the A/C's (50 amp rig 2 of them) sometimes one worked, sometimes the other, both or neither.
First stop on the tribble search was the power distribution panel (Breaker box) also, as it turned out, the last stop.
The wires clamp to the bus bars and to the breakers with screws. One of 'em took over THREE FULL TURNS before I Called it tight.
The result of this is I have a saying:
Many RVers have a few screws loose
And no you know EXACTLY what Screws I'm speaking of.
Mine took either a #2 Phillips or Square (Also #2) square worked best
As my favorite RV-Girl (That's the license plate on her work van) says "When I tighten them they don't come loose" (We think alike on many repair jobs).
NOTE Of CAUTION
when you check those screws.
Unplug (from shore or portable generator) TURN OFF on board, NO 120 volts 12 is OK (Battery) and a flashlight if needed.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
