3_tons
Jan 25, 2021Explorer III
Dusty R wrote:
I've never seen that type of problem with a breaker. I've seen breakers that would not reset, And once seen one that would not carry the load it was rated for. I've also seen where they were turn on and off every day switching lights in a commercial/factory work/wear loose and heat up.
Stop up my way and I'll take a look at it.
Dusty
I only mentioned the breaker since it is a mechanical-magnetic device - the ATS could still be suspect, whether the contacts, coil or faulty logic board...Bypassing is the ticket!
HadEnough is doing some mighty fine sleuth work!!
3 tons
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
