dougrainer
Jan 26, 2021Nomad
time2roll wrote:
I find it odd to be the transfer switch since both the utility cord and on-board generator have the same issue.
Maybe start with isolating some circuits like setting the fridge and water heater to propane only.
You are not understanding a Transfer switch and also HOW the OP is doing his 120 power.
1. He states that his ONBOARD Gen is having the problem
2. He states his stand alone genset has the same problem
3. YES, his Stand alone uses the Shore power cord
4. BUT!!!!! His Stand Alone STILL uses the ATS relay with its contac points. The INPUT points are on BOTH sides of the relay. So, over the years he has probably pitted the points on Shore side and also on On Board Genset side. That is why I suggested he BYPASS the ATS and wire direct. That will determine very quickly what his problem is. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
