- Dick_BExplorerWas that suggested by a fellow RVer that you had a screw loose?
- cannesdoExplorerProblem solved. There was a screw loose on the underside of the lift mechanism causing the gear to drop. Tightened that up and it works normally again. When I removed the screen from the inside the gear dropped down on top of it. Looked normal from above (the roof) though.
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Jul 20, 2015
