Ropdoc's avatar
Ropdoc
Bathroom vent fan
Hello all,
I have a temp control ceiling vent fan. The open portion of the controls works without issue. But the fan doesn't run. I took it apart and while apart it runs, but when I put it together it doesn't run. I took it apart a second time and again while apart it runs. I assembled it while running and ran without issue, but a couple hours later I turned it off but it would not run again. Any ideas what is going on?
Thank you for your time.
  • Hello all, any advice where I can get the housing for the motorized knob? It has shattered.
  • my fan did that and when I called the company they told me to clean the plunger switch. never entered my mind to do that. after that it worked like new.
  • Usually when they open but not run it is the lid switch. There should be a plunger type switch which only allows the fan to run when the lid is open. It is probably dirty or corroded.
