SWFL_FlyFisher
May 22, 2018Explorer
Other than the sink draining into the tub, are there any other issues (does the tub drain if the sink is not in use)? If it empties properly with your new setup and the only problem is sink water draining into the tub, why couldn't you give each a dedicated drain line into the grey tank as in your "fix" above, but rather than plumb into the side have the new line go into the top like the original?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
