time2roll
May 22, 2018Nomad
The fix looks like you are dropping the tub drain line below the floor level shown in the picture. I like the solution if you can make access to that area. As long as the tub is higher or level with the top of the tank I think it will work fine with no need to raise the tub.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
