time2roll
Feb 06, 2016Nomad
At some point the 9245 should produce 40+ amps into the low battery.
Converter will produce 14.4 volts at the converter. Battery is a bit lower during charge due to voltage drop in the charging loop.
Four hours is long enough for running the generator. I would go one hour more once amps start to taper off below 40.
Bogart makes a good solar controller to go with the 2030.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
