CA_Traveler
Feb 07, 2016Explorer III
hondochica wrote:I mean check at the charger and the battery to see the voltage drop due to wiring. Do this when bulk charging as the current will be higher resulting in more voltage drop.CA Traveler wrote:I presume you mean check the voltages at the battery while charging? I have an old analog voltmeter - will it suffice? - and thanks!
Buy a $10 digital voltmeter (or borrow one) and check the voltages. You may find a substantial voltage drop in the PD wiring.
For battery voltages a digital voltmeter is by far the best due.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
