time2roll
Feb 07, 2016Nomad
hondochica wrote:If you see 14.4 almost immediately on the TM all is probably fine.
Let's try a different browser:
To smkettner I have seen 14.4 on the trimetric when charging. I have never seen 40 amps, but then I don't generally run the batteries below about 12.3 (70% +-); most amps in I've seen was about 16. I ran gen >6 hours till amps in dropped below 1.
Kelly
If voltage steadily rises over maybe an hour you should initially see 40+ amps. Could be the wire is a bit long and thin.
Browser is not the issue on posting. It is RV.net server. More specifically the RV.net portal. Use the woodalls portal if trouble with RV.net and you will post every time.
(this post made through woodalls)
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
