hondochica
Feb 08, 2016Explorer
If you see 14.4 almost immediately on the TM all is probably fine. I almost never see 14.4 - it is rare
If voltage steadily rises over maybe an hour you should initially see 40+ amps. Could be the wire is a bit long and thin. Voltage can rise over a few minutes from say 14 to 14.2. Best amps I've seen were 18 in - but that is rare also. Wire from the PD looks to be 8g out of the PD; where or what it does from there - I have no idea. I'd have to tear half the RV apart (slight exaggeration) to tell.
Thanks!
Kelly
Thanks!
Kelly
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
