pianotuna
Mar 30, 2022Nomad III
Lantley wrote:
Currently I have AGM's and a small inverter powering a TV and nothing else.
Very simple install as I seldom boondock and I have a built in Onan 5500 if I really want power.
What had me questioning AGM vs. typical lead acid is the idea that water levels need to be checked once a week. If once a week monitoring is truly required, than it seems AGM's are the only way to go regardless of cost because once a week is a cumbersome task to me.
Before I went with AGM's I had lead Acid and I checked maybe 3-4 times a year at random intervals, But I was not running an inverter.
Is it that running an inverter necessitates weekly checks? Is it the size of the inverter and frequency of use that factors into weekly water checks?
Or are weekly water checks not necessary?
A small inverter has little or nothing to do with checking fluid levels on wet cells. What does is poor converters.
What size wattage is the inverter?
I had wet cells--but got tired of checking water levels laying down in snow.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
