Another problem. Was really cold and batteries were low , had to put on auto charger. Question where is the inverter/power box located(most times), and should it keep batteries fully charged?
Converter charges the batteries If you are plugged into shore power The charge section of an inverter/charger combo does the same thing Unless it has been turned off, unplugged, etc..
Make model of RV? Somebody can tell where it is in their RV Mine is one of the storage bays 97 Bounder ... Passenger side under the kitchen 95 Safari DP, driver's side rear, next to generator compartment
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
