ArmySFCRet wrote:
Disconnected bats and now on external charger. Will wait and see. Using large roll away with gauges. Currently charging at about 18 amps.
On edit: after 45 min, now up to 20 amp charging rate. This is in low setting. Medium setting takes it to 39 amps.
These threads can get out of hand-and people don't read every post-what you suggest above sounds like a good plan-I've had similar experiences and you need to tackle both issues-why the batteries are dead, and charging them back up! My experience has been to top off the batteries with distilled water and then charge at the lowest rate possible-ideally for a few days-let them sit and rest and then charge again and then hit them with a good high rate charge after they've settled for a few days and are maintaining there charge. I takes the plates some time to 'remember' their job, hopefully there not toast and if they were just drawn down and not that old you'll be ok.
Just to confirm-and I'm being super simple minded-you have 12V batts and not 6s right?
