MEXICOWANDERER
May 01, 2018Explorer
You should have heard the cooling fan and the battery voltage should have gone up substantially after several hours of charging. It is possible your charger has died, but that seems too coincidental. I bet your batteries have died and your charger will work just fine with new batteries. You can go to a battery shop and have them tested.
Troubleshooting error
Converter online and functioning would be heavily loaded by rationale of the voltage reading.
It is quite likely power to or from the converter has faulted
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
