Harvey51
May 06, 2018Explorer
When a battery is charging it’s voltage is the voltage of the charger. Disconnect the charger for at least a couple of hours to get an indication of state of charge from a voltage reading.
I have a smart charger with equalize mode but in this case I would use my little bench variable power supply because I can set it at 14.8 volts for a few hours. Dumb can be better than smart because the charger doesn’t know what happened to the battery.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
