SJ-Chris's avatar
SJ-Chris
Explorer II
May 01, 2018
Batteries drained because lights left on...how bad is it?
I retrieved my RV from storage today where it had been for 14 days. When I entered the RV I immediately saw that the interior lights (LEDS) were on. Yikes! They were on for 14 days straight. I do not have solar. I have three 12v deep cycle batteries in the RV living quarters that were all purchased new about 6 months ago. These batteries were all fully charged prior to putting away in storage 14 days ago.
I checked the battery voltage on the battery terminals (I've got a bluetooth monitor on them) and it said 11.4v. On the short drive home (about 1 mile) the voltage went up to about 12.4v while the engine was running (as the chassis alternator was trying to give them some charge). When I got home I plugged the RV in to shore power so the converter can give it a charge overnight.
After about 5 hours of being plugged in, the voltage on the batteries is at 11.7v. Seems like it has been there a while. Is this common/expected?
I've got a WFCO 75amp converter that is only about 6 months old. Very often over those 6 months when I plug into shore power it was common to hear the converter fan kick on and it sometimes would stay on for a couple hours before finally shutting down. So far, being plugged into shore power for about 6 hours now trying to charge the dead batteries I have not heard the converter fan come on at all. I thought that when under a heavier load and trying to charge the batteries it was common for the converter fan to kick on...but so far it hasn't.
From your knowledge/experience, what sort of damage did I do to my batteries? Is it reasonable to expect that they will mostly recover if I charge them for a very long time? How long should I expect to recharge them?
Thanks!
  • On the short drive home (about 1 mile) the voltage went up to about 12.4v while the engine was running (as the chassis alternator was trying to give them some charge). When I got home I plugged the RV in to shore power so the converter can give it a charge overnight.
    No... Seems the wfco is not charging. You should be up over 11.7 because the truck was charging @12.4. And yes the wfco fan would come on non stop at that low level.
    Possibly the breaker/fuse on the frame rail is blown? Need more info.
    You need to do some testing on the wfco. Ill post a link, but in mean time get those batts on an external charger ASAP.
    http://wfcoelectronics.com/wp-content/uploads/2015/11/New-Flow-Chart-for-WF-8900-Series.pdf
  • You'll be fine. Just keep your camper plugged in.
    You don't need fancy instruments to determine the health of your battery. Just unplug the camper from shore power. Turn on a light and see how bright it is. Now turn on a second light. If the lights dim noticeably, the battery is either weak or not fully charged. It's just that simple.
    Keep it plugged in. It will be fine.
  • The batteries will be fine. The wfco was a mistake in my opinion. Let it charge on the wfco and monitor it in case wfco isn't bringing it up. Maybe get a new progressive dynamics arrives.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
