BobsYourUncle's avatar
Aug 21, 2019
Batteries drained to dead, what is nominal drain on truck?
18 days into a 3 week holiday, things were mostly well until this morning, sigh, here we go again....
Parked the truck at the campsite day before yesterday afternoon. Didn't run it yesterday. Went to head out this morning and the truck wouldn't start, batteries were dead. Enough juice to make the solenoid click a bit, that's all.
What the heck? Feb 4 this year, 2 new batteries, March 8, new alternator.
When I tried to start it I had a weird smell come out the AC/heat ducts. Not quite a burnt electrical smell but similar.
I'm baffled here. Thing was running fine until this.
Pulled the negative terminals, put on an ammeter, looked at readout. Started at 1.67A, bled down to about .11A and stayed there.
Left the batteries disconnected for about 7-8 minutes, hooked them up and ran jumper cables to my TT house batteries. Gave it a couple hours for the converter to charge them a bit.
Got it started, ran it a few minutes, alternator got hot rather fast, but it's working so I get that.
Took it for a run for about a half hour, seems to be ok now. Except that weird smell...
It's been a couple hours shut off now, going to go back out, pull the negs and do the ammeter test again.
My question regarding all this:
What is the nominal draw in amps that should I be reading? That is, the normal amount of parasitic drain? Milliamps I guess, not amps.
(TV in sig)
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
