BFL13
Aug 21, 2019Explorer II
Did you power the converter from shore power or from a generator? reason to ask is:
If you are off grid, and you leave the 7-pin connected while parked engine off, your Chev will be "live" with the engine battery in parallel with the trailer batteries. So that could be good or bad for the truck battery depending on whether the trailer batteries are being recharged or run down.
Generally with a Chev, disconnect the 7-pin when you are parked for very long.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
