SoundGuy
Feb 26, 2017Explorer
red31 wrote:
the point is temp comp for long life, this prevents over and under charging.
under charging leads to sulfate, under charging leads to additional battery maintenance. Flooded require it also for optimal life. Solar provides this easily. lead acid is lead acid
so just how un optimal is battery life of Deka's AGM if charge with a smart charger set to their recommendation without temp comp? precision please!
Why ask me? - ask East Penn :R ... and while you're at also ask why a temp comp warning is not also listed on their flooded line, since you're so "precise". :W
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
