valhalla360
Apr 08, 2023Navigator
bka0721 wrote:pianotuna wrote:bka0721 wrote:
Is there a limit on how many batteries can be connected in parallel?
No if they are wired in a balanced manor.
Define; a balanced manor
Glad to see you are still around, Don. Hope all is well with you.
b
Basically the path thru each battery should be as close to identical as possible and each battery should be in the same condition:
- Avoid having major differences in cabling size/lengths between batteries.
- Make sure all connections are clean and solid.
- Make sure all batteries are of the same make and model put into service at the same time and exposed to the same usage.
For a couple of batteries in the same compartment, it's usually not a big deal. If you have one bank at the front and one at the rear of the RV, balancing gets a bit more difficult. Basically, the systems will try to charge and discharge the batteries with the least resistance first.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
