OnaQuest
Jun 08, 2013Explorer
HiTech wrote:If there was enough sidewall flex to cause noticeable leaning in a motorhome of that size, the tire would have to be dangerously and obviously under inflated, period.
More lean is party from sidewall flex in the tire.
HiTech wrote:I posted my comments at 10:45, you corrected your statement at 11:15, am I supposed to be clairvoyant?
I corrected my prior statement, remembering that you need symmetry on the axle. Apparently you decided to not quote that statement?
HiTech wrote:Because you can't quote something that doesn't exist. Sorry, but I didn't think it necessary to quote the rest of your yada yada so I deleted it.
No I won't quote the ford spec for pressure differential
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
