OnaQuest
Jun 08, 2013Explorer
HiTech wrote:
If it was right even between axles, it is equivalent to adding 1000 pounds to the rig. If right over a single axle, it has the same impact on that axle as adding 2000 lbs. overall. At the least tire pressure adjustment is in order.
Really you are supposed to air up all tires on the axle for the heavier load. I like to air the outsides on dualies a few pounds higher than the inside tires for stability (up to a 5 psi difference is still within Ford specs).
Could you explain how this happens?
So, if I add 500 lbs exactly on top of each axle, it's really adding 4000lbs overall?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
