OnaQuest
Jun 08, 2013Explorer
HiTech wrote:
Look at my 8:50 am post.
500 pounds over one end of one axle (say batteries right over the wheels) affects that corner the same way as 2000 lbs added to the center of gravity of the vehicle.
Jim
That's BS. (besides, it;s not exactly what your prior post says.)
2000 lbs at the center of gravity will not cause the box to lean. 500 lbs on one corner will.
You are considering only the weight on the axle, and trying to level it out with tire pressure (which cannot be done) and you aren't considering spring depression and flex.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
