PaulJ2
Jun 08, 2013Explorer
HiTech wrote:
You can get into recurring springs as well. Or just move a battery or some of the other loads.
But for movement in side loaded winds, ensuring the inner wheel is no higher in pressure than the outer is critical, and I don't think anyone who has put the pressure a few pounds higher on the outer dually has told me it did not help.
Jim
I have had all this explained this way: Since most roads/highways have a slight "crown" for water drainage etc more of the load is carried by the inner dual tire. Therefore by increasing the air pressure by 4 lbs on the outer tire it increases it's diameter very slightly causing it to carry a more equal amount of the load.
This should equalize the tread scuffing in turns also.
Now this is all big rig stuff but I'm sure will apply to dualies also.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
