tenbear
Sep 29, 2013Explorer
IMHO, I think the battery charging and the lights are unrelated problems, but possibly not. I suspect the lights is a ground problem. Measure the voltage, or use a test lamp, using a separate ground.
If the wire from the distribution panel and the converter to the battery is good, maybe that is a ground problem, either at the converter or the battery.
BTW, is this a TT, smallish MH or a DP?
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
