12rvjoe's avatar
12rvjoe
Batteries question
i was wondering if there would be issues of adding two six volt batteries independent of the factory twelve volt set up. I want to add the six volts and charge them using a generator , until I can get solar set up and run cable to the inverter only and plug in the shore power cord to the inverter. thoughts ?
TIA, Joe
  • What you wish to do can be done. However, when drawing on the inverter, it would be better for it to draw on all possible batteries. Add a switch similar to this one from Napa
  • Sorry, I mean to not have the six volt batteries hooked to or connected to the trailer in anyway other than through the inverter and power cord
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
