Reddog1
Aug 01, 2014Explorer II
James' wrote:I was hesitant to mention the heated and flattened ABS pipe. Home Depot used to stock ABS sheet (1/8" thk). Plastic supply stores stock it in different thicknesses. If your box is ABS, which I doubt, you could just use the ABS cement. I have used scraps and chips from sawing mixed with the cement for big holes/gaps, and just ABS for cracks.
Q-Bond, what can I say WOW! filled in the areas with heated and flattened ABS pipe and used the Q-bond to fill in the cracks. I can now add the T-105s.
I think the Q-Bond is just crazy glue. Seams to me, baking soda in a crack with a few drops of crazy glue does the same as Q-Bond and the powder they provide. I have not tried it yet.
Wayne
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
