3boutlaws's avatar
3boutlaws
Battery / breaker issue
I have a one year old class A Thor Outlaw. I had it plugged in all winter. This summer the chassis battery is fine but the house batteries were bad! I replaced both House batteries with good new marine ones. When I reset the breaker on the battery terminal on the wall of the battery compartment the chassis battery instantly begins to boil and the breaker trips again. Could this be a bad isolator?
  • I just had a WFCO 8955 putting out 21 volts. Fried the battery pretty well. There are two 2 amp resistors that got hot and came unsoldered.
  • What is the house battery and charger voltage? Have the chassis battery load tested.
  • First thing to check is the house battery configuration, be sure they are connected in parallel. Almost sounds like you are pumping 24v into your chassis battery.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
