enblethen
May 28, 2018Nomad
Your fusing needs to protect the wire.
The fuse should be the same or smaller rating then the converter. 60 amp fuse would be good.
The genset could go directly to the battery lead and not go through a fuse.
The two bolts marked fifty amp looks to mount a fuse. verify spacing.
Look for some identification on the fuse panel and post it. I cannot read information in lower left corner of third photo.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
