pvelit's avatar
pvelit
Lithium Upgrade - Converter charger
Hello, I have a question: Can I use a "voltage Booster" after my smart convert/charger (3 stage charging - 45 amp) to boost the 13.6V to 14.4V needed by my new Lithium battery?
I just updated to new Lithium batteries, and a 300W solar panels. However. I would like to also be able to charge my batteries using the original converter/charger when plugged into AC power.
The "voltage booster" I have... I can set up the:
- Max output voltage from 12 to 60. I will set it to 14.4 or 14.6
- Constant current regulator. I will set it up to 30 max.
Looks like it should work. However, I am confuse on how the converter charger will behave since it has the 3 stage automatic charging.
If anyone has any insight please share.
Thank you,
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,400 PostsLatest Activity: Jan 28, 2026
