Lwiddis
Oct 04, 2017Nomad
“Question: If I remove the battery quick connect/disconnect, does this remove all draw from the battery? I am under the impression that it does.“
When turned off mine does except for the tongue jack...self installed. If your’s is factory installed you’ll need to trace wiring and test. What brand and model is your TT? Someone might know. A solar panel would have kept your batteries up.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
