howardq99
Oct 23, 2016Explorer
Thank you everyone for your input, advice and suggestions!
I’ve had family obligations so I’ve just now been able to read the replies...
So for the short version:
Mr. Wizard, now that I’ve looked at the wiring diagram of the Blue Sea 9001e and I see what you are saying about only the positive leg.
Do you think I could use something like a DC combiner in place of that battery switch? Use equal lengths of wire from both banks of 12V jars (two 6V batts in tool box to make 12V bank) in parallel to a DC combiner and then on that output connect the 12V inverter? If I keep all the parallel cable lengths equal would this keep the batteries balanced by drawing from both jars equally?
Long version:
What I am trying to do is make a portable system that I can use in the trailer when we go camping (always boondocking, many weekend trips with a 2 week trip every year) and then…
Its MAIN use and purpose will be as an emergency backup at home. For emergency backup I’ve done an energy audit and the four Fullriver batts are the right size to run my critical systems. Combined with the Midnite charge controller and the 8 panels I can easily juice the AGMs at 20% of their C/20 Ah rate to keep them happy. I know this is overkill but it will allow me to run additional loads while the sun is shining and charge the batteries too.
I’ve already purchased the 12 panels and the 12V inverter, I'm about to pull the trigger and order the Midnite Charge Controller and the four Fullriver batts. Unfortunately, that just about blows the solar budget for this year so a 24V inverter (looking at a Magnum Hybrid) will have to wait until next Fall.
I’ve got no problem moving the gear back and forth as I am building this out in portable cases. I will have the batts in two separate case, each a big 12V battery (130lbs!). They will be on caster wheels with equal length 2/0 cables used to interconnect (along with proper fusing and circuit breakers). My trailer has a toyhauler ramp in the back so I can easily wheel the batts and gear in and out of the trailer when it’s campfest time. The trailer is too long to fit at my house so I can only really keep it overnight one night maybe two nights in a row at most.
If you look at these pictures
https://www.amazon.com/photos/share/MCon3qJOmwoCuIHPWqvCKVcMZdfjXVIuZHJ4Ibw2nB0
you can see I’ve built a test unit with Rigid tool boxes, two T-105s, a Tracer 4215BN charge controller and the Xantrex 12V SW2000 inverter. I’ve used 4/0 wire from the batts to inverter, 2/0 between the two 6V batts and 4AWG from the charge controller to the batts.
This set-up works great but it is not enough to keep up with all the critical loads at my house. I also want to dump the maintenance and gassing of the FLAs and go with AGM batteries.
So until I can spring for a 24V Magnum inverter next year my hope WAS to put two 6V AGMs into one Rigid case to make on large 12V jar. I would make two of these big 12V jars (let’s call them jarA and jarB). I would connect jarA and jarB in series to take advantage of the Midnite charge controller and the 8 solar panels . Then connect (+) and (-) cables from jarA to the Blue Sea battery switch bank1 and connect (+) and (-) cables from jarB to Blue Sea Battery switch bank2. I would connect this to the inverter and always keep the battery switch on bank 1+2 so I would always be using each bank equally. I was hoping this would let me use the current 12V inverter until next year.
Long version:
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
