howardq99's avatar
howardq99
Battery Bank/ Inverter Question
My goal is to build a semi-portable system to transfer between my house and my trailer. I have twelve 285W Silevo solar panels four of which I will be mounting on the trailer and eight for the house. I will be using a Midnite Solar Classic 150 charge controller, four 6V Fullriver DC250 AGM Batteries and I have one Xantrex Prowatt SW2000 12V Inverter.
What I am hoping to do is to configure the four batteries in series for 24V to be able to maximize the power harvest of the eight solar panels at my house (the Midnite string sizing tool will allow this 24V battery configuration with four parallel strings of two panels). If I drop the battery bank down to 12V I can only use four panels at a time.
My question is can I configure the 12 volt inverter to be used with a Blue Sea 9001e dual bank battery switch to pull power from each 12V set of two batteries (so to speak a sub-bank 1 and sub-bank 2) while keeping all four wired in series? The Blue Sea switch has a setting for bank 1, bank 2 or banks 1+2.
Thanks for your input!
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
