mena661
Feb 02, 2014Explorer
As BFL mentioned, you need to put all the negatives on one common bus and all the positives on a different common bus.
This is how I did it. Those are Blue Sea bus bars.
EDIT: You can see the shunt for my Victron battery monitor connected to the negative bus bar. The "other side" of the shunt is connected to chassis ground so I get everything the comes and goes to batteries.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
