skipnchar
Feb 02, 2014Explorer
Wire each pair of 6 volts together positive to negative then wire the three sets together positive to positive and negative to negative. Wire ONE lead on the negative side to the RV negative and one positive lead to the RV positive lead.
Each set of 6 volt batteries is made into a large 12 volt then you wire the 12 volt sets together just as any other 12 volt batteries to maintain 12 volts as the output.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
