wa8yxm
Oct 25, 2017Explorer III
There is resistance but it is too small for your meter to measure.
When you are measuring positive to positive.. The entire system is still there.. current can easily flow. I'd not worry about it and do not test that way
To test With the engine off and shore power on test each terminal for VOLTAGE reference to ground. If the chassis (Engine) is 12.x and the house 13.xc YOu can use the Trick-L-Start.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
