Slownsy
Sep 26, 2016Explorer
Battery cables
i am including to pictures of my 4 6V batterrys please nominate top or bottom setup for my cables to 12V.
RoyB wrote:
I like what MR WIZARD says but my problem is I can never come up with the room to situate my batteries that way... Then my two connecting cables in the middle become long cables...
If I had the shunt I would always put it in the NEGATIVE FRAME cable. I never liked the shunts as that makes one of the Voltmeter leads HOT Voltage which is routed back inside the trailer to where your Voltmeter is located....
Using a Hall Effect transformer to measure DC CURRENT is best to use IMO...
The Fuse of course should always be in the cable that is supplying the source 12VDC. Its purpose is to protect the cables in the event the source gets shorted to frame ground. All those batteries connected can produce a very large amount of current if direct shorted to frame ground (literally hundreds of DC AMPS..) The fuse also has to be the right value to handle all of your normal 12VDC needs without blowing the fuse.
My two sets of 6VDC batteries wired in series wiring would look like this...
Google Image
All like cables inside the wiring must be the same lengths in order to make the DC currents be same between all of the like connections...
Just my thoughts
Roy Ken
