Mkos1980's avatar
Mkos1980
Battery charge not reading full.
Just brought the trailer out of storage and put in a brand new battery and the indicator light is only shoring 1/4 charge. I work at Advance Auto so I tested the battery and its perfect. When plugged into the home it still reads 1/4. I put a multimeter on the battery while it was plugged in and it was showing 13.7-13.8 so I know it was changing. It worked perfect when I put it away last year. Any thoughts?
  • If you are referring to the inside "panel indicator light", those things are notorious for being incorrect. I never even look at mine anymore. Use a meter on the battery itself and have a nice time. I know you want it to work correctly, we all do, but fact is they usually don't. Good luck to you.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 27, 2025
