SHRED's avatar
SHRED
Battery charge questions
My new motorhome's
system is this:
Blue Sky 3000i solar controller.
2 - 115 watt pv panels.
Parallax 8355 converter with 3 stage charging and TempAssure sensor.
2 Lifeline AGM 6v batteries.
Being a newbie to both solar and AGM I was wondering if this system will keep my AGM batteries topped off properly?
I've heard that AGM batteries require a higher voltage to maintain a state of charge and don't want to damage them.
I'll most likely leave it parked in the sun and unplugged when I'm home between trips.
  • I had one of those a few years ago. It is a 4455TC IIRC. Specs on their site. You must install the TC module to get stages. Otherwise it is single stage at 13.x. The TC wire to the battery has the sensor on the ring terminal that goes on the neg battery post IIRC.
    I got 60 amps from the "55 amper" using #4 AWG wire to the batts. With #8 it only did the 55. It worked as well as the Iota a guy on here had when we did a "shoot-out" contest.
    It did more like 14.2v rather than the usual 14.4, but it still got the job done.
  • 2oldman wrote:
    You can look up the charge specs. Parked at home, yes they will stay charged. When camping, that depends on your usage.
    I'm having a tough time finding the specs on the 3 stage Parallax charger.
    I installed a Progressive Dynamics converter on my previous motorhome and they very clearly spelled out the specs for each stage.
  • Good solar charge controllers come with a temperature “probe” to be placed near the batteries.
  • Charging voltage varies depending on temperature. See your battery manual at page 19. I don’t recommend going by what you’ve heard.
    https://lifelinebatteries.com/wp-content/uploads/2015/12/6-0101F-Lifeline-Technical-Manual-Final-5-06-19.pdf
  • You can look up the charge specs. Parked at home, yes they will stay charged. When camping, that depends on your usage.
